LabVIEW Embedded
No targets....
Hello again,
I have just installed LV 7.1 Embedded Edition + LV Embedded Dev module 1.0 but i dont see any execution targets. When I navigate to:
C:\Program Files\National Instruments\LabVIEW 7.1 Embedded\resource\LabVIEW Targets\Embedded
Then directory is full of example targets....What i do wrong??????
Marcin
(7,783 Views)
Hi Marcin,
You need to activate the Embedded Module in NI License manager before any targets will appear.  The instructions to do so should be on a piece of paper that came in the software box.   If not, here's the easiest way:
  1. Start>>Programs>>National Instruments>>NI License Manager
  2. Under LabVIEW 7.1>>Modules there should be an Embedded Module
  3. Right click and choose Activate...
  4. Follow the instructions
  5. Once activated, the targets should appear
I hope that this helps.
P.J.
(7,773 Views)
Hello pjtanz,
It helped.....:)
Thanx
Marcin
(7,765 Views)
