LabVIEW Embedded
NI CAN
Hi I am getting  Error Code: -1074388885 CAN Write (Multi-Chan Single-Samp 1D Dbl).vi. I am trying to Send and receive some CAN message on the Bus. If the power for Bus in not ON at the beginning, then I get this error. If the i keep power ON and the run, the Logic works, but during runtime if i switch off the power and bring up back the message which I was transmitting does not get transmits [it stops]. Thanks,
Mithun
Message 1 of 1
(6,236 Views)
