LabVIEW Embedded
Luminary Micro LM3S8962 Quadrature Decoder
Has anybody started to look at making use of the built in quadrature decoder functions available on the LM3S8962?
There is always the alternative solution of using digital elemental IO to do this but the fastest loop execution time with the ARM targets seems to be 1kHz which makes this solution impossible for my task, I need something much faster to accurately track the encoder count.
Phil
(6,322 Views)
Hi phil_dal,
Currently, there are no VIs that access the encoder, and I do not know of any immediate plans that involve making those VIs.
Keep in mind that you can access that peripheral yourself via the Inline C Node in LabVIEW though.
I hope this helps,
Kevin S.
(6,304 Views)
