LabVIEW Embedded
LabVIEW embedded ARM target and LPC2148
I'm trying to run LabVIEW application on LPC2148 ARM ucontroller.
I followed example on NI website (Tier2 ARM device with the LabVIEW Embedded Module for ARM Microcontrollers).
I have a project template for LPC2148. I prepared very simple application
(one loop with shift register). Application compiles, loads into memory, but
hangs in SWI_Handler. SWI_Handler *IS* imported in Startup.s. I can't even
debug the problem, because RTX comes as a binary blob. I have no idea where to start
looking (no source code == no debug == I'm blind).
Can anybody help me with some guidelines about porting LabVIEW to tier 2 processor?
Any experience with such port?
Some data:
* LabVIEW 8.5.1 with ARM target (not evaluation, *NO* Microprocessor SDK)
* Program loops in
SWI_Handler:
(...) // some machine code
0x00008938  EAFFFFFE  B         0x00008938
* Stacks set as in MCB2300 template
I will provide any other information if needed.
(10,197 Views)
i have arm board with processor LPC2148.
I wnat to use labview arm module.
Can i use labview arm module for LPC2148?
(8,604 Views)
Hey , I hav a query. I hope you reply to it. I am trying to make my LPC2148 Dev Kit a target in LabView, and unfortunately i am unable to do so. Can you please tell me how do i make it a target. Also do tell me wat all is needed. Please Reply ASAP.
(8,062 Views)
You should look at the template folders of some targets that are availabe with LV for ARM.
You can copy/paste and edit a target for your device (adding peripheral library and editing LV for ARM drivers like ARM_serial.c)
First you'll have to know the structure of a LV for ARM application.
I suggest that you make a simple application and then build ik for an existing target (luminary or NXP)
after the build is complete, you can view the uVision project via Tools > ARM > open KEIL uVision.
Wouter.
"LabVIEW for ARM guru and bug destroyer"
(8,023 Views)
Hey bro , can you please send me the LPC2148 template folder, i am in urgent need of it, for my final year project.
I tried creating it but got stuck at mutiple places.
my emailID is rucheyu@gmail.com.
Please Help.
(7,914 Views)
