‎04-23-2010 03:35 PM
Please reply to this discussion thread with any feedback on the LabVIEW Real-Time Skills Quiz.
‎05-05-2010 12:47 PM
21 out of 24 correct. This one got me because it says (correct answer) at the end... but its the wrong answer...
‎05-05-2010 02:31 PM
Thanks for catching that, David.
We will get it fixed.
Nice job on the quiz!
‎12-11-2010 04:14 AM
‎12-13-2010 09:28 AM
The main point is that the loop is driven by the event of a DAQmx sample being available. Therefore, you should synchronize the loop with the scan clock on the DAQ board (which is what they are referring to as an external clock) not because it's a lower-jitter clock (although in some cases it is) but because it's the actual rate you are trying to run the loop. Using the PXI clock would just introduce an unnecessary second clock into the system, which will drift in relation to the clock you are interested in.
