LabVIEW Embedded
LabVIEW Embedded Module for ARM 2009 and LM3S8962 kit
Hi! I want to evaluate the LabVIEW Embedded Module for ARM under the LM3S8962 board, but ever I try to run a simple program like the ni.com tutorial (Draw a pixel on the OLED display), I receive a error message: "UVSC_OpenConnection (1)". I tried to reinstall LabVIEW and toolkit, I activated uvision in evaluation mode, I install the MDK322H for uvision and the problem remains... Thanks for the help! Evandro
(8,698 Views)
The problem is solved!
I installed the 2010 version of LabVIEW and Embedded Module and now they works. I think the problem in 2009 version is because the NI Service Locator wasn't running.
Now I have another question: I'm downloading my code to flash memory using the USB directly on the board (And under uvision, because in LabVIEW a error occurs when he try to enter in debug mode), how I can debug the LM3S8962 board without using the Keil Ulink cable? I can debug using the same way to program or the ethernet cable, for example?
Thanks!
(8,690 Views)
This is KIRAN KUMAR.VAKA, WORKING IN HBL POWER SYSTEMS LTD, HYDERBAD.
I AM LEARINING EMBEDDED NOW, PLEASE PROVIDE TOOLKIT & KEIL SOFTWARE CDS
(8,395 Views)
hi.. i am using labvew 2012, i am do the proggrame of LM3S8962 ARM controller of texas but do not download the proggrame in kit and generate the error UVSC_OpenConnection Code: 1
(7,505 Views)
hi.. i am using labvew 2012, i am do the proggrame of LM3S8962 ARM controller of texas but do not download the proggrame in kit and generate the error UVSC_OpenConnection Code: 1,
So plz give me better solution for this error, i am waiting for your solutions.
Purvik Patel
(7,503 Views)
 if you installed the toolset for microntroladores ARM, you must have Jan mind that these examples are designed to be downloaded to the ULINK2 Keil, must re-compile for you download the USB port if you have built the recorder
(6,969 Views)
