LabVIEW Embedded
LV Embedded Development on this target ?
Hello!
This page shows a ARM7 uC with Linux 2.4 :
Is it possible to use it with LabVIEW ED Module ?
Best Wishes
Andy
(7,614 Views)
Hi Andy,
This looks like a great potential hardware solution for LabVIEW Embedded. In fact, the LabVIEW Embedded Development Module 8.2 contains an example target for an ARM LPC229x target. There are 3 things to look for as you consider other possible targets for LabVIEW Embedded:  at least 256KB of memory, a 32-bit microprocessor, and an OS.
Michael P
(7,606 Views)
That means, it is unrelevant, which OS is implemented on my target ?
uClinux with Kernel 2.4 or 2.6 is no problem ?
Are there examples for an ARM9-Core (the Atmel AT91RM9200 f.e.), too ?
Andy
(7,596 Views)
Andy,
So far, LabVIEW Embedded has run on VxWorks, eCos, Unix, Windows Console, VDK, DSPBIOS, and QNX. The kernel version of uClinux is not likely to have an effect on the experience of using LabVIEW Embedded, unless there are specific improvements in the kernel that you need to take advantage of.
Michael P
(7,592 Views)
