LabVIEW Embedded
LPC 229X
I am trying to devolop an embeded application for the LPC 229X target.I have both cygwin 1.5.1 and ecos 2.0 installed in the proper directory and alse changed the PATH variable path.But while i start to ceate the exe it gives a linking error, I am not using any hardware during the exe creation.
"Failed to create Executable
gcc: installation problem, cannot exec `cc1': No such file or directory"
Can anybody provide me with some valuable suggestion.
:mansad:
(8,311 Views)
Did you install the arm-elf toolchain from ecos.sourceware.org? You need to run these commands in cygwin:
wget --passive-ftp ftp://ecos.sourceware.org/pub/ecos/ecos-install.tcl
sh ecos-install.tcl
This requires that you have the Cygwin packages for TCL/TK and WGET already installed. You also need to make sure that the toolchain installs in either cygwin\gnutools, cygwin\opt\gnutools, or cygwin. Otherwise, the toolchain will not be found in the Path system variable.
Michael P
(8,300 Views)
Hi Michael,
I have installed cygwin and ecos in the required directory....I have attached an image of the folder structure with this post...please check it...but still i am getting the same error...in the build properties i have given the path of the compiler and linker path as like this...
"C:\cygwin\gnutools\arm-elf\arm-elf\bin\gcc.exe", "C:\cygwin\gnutools\arm-elf\arm-elf\bin\ld.exe" ....any suggestion?
Smiley Indifferent
(8,295 Views)
I tried to find out what is the command that were passes on to the linker from LV.Since the VI 'LEP_ecos_Phytec_LPC229x_ScriptLinker.vi' is used for this I went inside this, but this VI is giving broken arrow. The source of the error seems to be in System Exec.vi which is showing broken arrow. The error that is popping up is "Code Interface Node:Node not supported for current target." .Any suggestion to solve this problem??????
Smiley Sad
(8,273 Views)
That VI is run in the Windows (My Computer) context. Verify that you have the plug-in VI open in the correct context (shown at the bottom left corner of the window).
Michael P
(8,266 Views)
Right you are,opening the vi s in the windows target(My computer) does not creates the broken arrow.But any suggestion for the original problem???
Smiley Indifferent
(8,261 Views)
The error you are getting is coming from gcc (gcc: installation problem, cannot exec `cc1': No such file or directory"). I looked around on gcc/cygwin forums, and most recommend a reinstall of gcc when this error occurs. Also, make sure you have selected the DOS/text option when installing Cygwin (not Unix).
Michael P
(8,254 Views)
