LabVIEW Embedded
LM3S8962_I2C_RW_AT24C02 EEPROM
LabVIEW for ARM V8.6
The address 0 EEPROM page datas are why did not modify?
Message 1 of 8
(10,391 Views)
Try this snippet (or redraw your diagram in 8.6)
Message 2 of 8
(10,364 Views)
Thank you for answering!
I wrote a program in accordance with the picture, but running, reading back the data is 0xFF, do not know AT24C02 chip is broken?  tomorrow to buy chips, then a response ... ...
Message 3 of 8
(10,358 Views)
EEPROM chip replacement, and test did not succeed, the result value is 255?
Message 4 of 8
(10,333 Views)
Have not run well in the I2C example? Today connected to the clock chip DS1307, during the debugging, the data to write and read  is also wrong. . .
Message 5 of 8
(10,316 Views)
Here is my running for the AT24C02 chip program results, in the front panel the Read Data does not display the results? Always gray state.
Message 6 of 8
(10,294 Views)
I observed with the oscilloscope on the signal waveform SCL and SDA. This two signal lines up-pulled 10K resistor. No run-time waveform created?
Message 7 of 8
(10,249 Views)
Accepted by topic author mcusir
Hi, read and write on the AT24C02 chip finally succeeded! Chip address only low 7bits effective. Do not add read and write bits.
Message 8 of 8
(10,191 Views)
