LabVIEW Embedded
How to use Colink2 to download and debug the routine on the EM-LPC1100LK board?
1. Application environment1) Colink2 can only be used in Windows XP operation system, supports SP3 and  higher version.2) Debugger and the the target board should using the common GND.3) When debugging using Colink2 integrated on the LPC1100 development board, it is recommended to use MDK4.03 version, because MDK4.03 just began full support the LPC1100.2. Colink2 for LPC1100 JTAG Debugger Features
Ø       Only support LPC1100 Series currently(Can support other Cortex-M0/M3 MCU later)
Ø       Support SW/JTAG debug and Download
Ø       Download speed up to 110Kb/s
Ø       Flexible debugging socket, support 20/10/8 pins connector
Ø       Support Keil MDK and CooCox full series software
Ø       Debugging conditions: use SW debug, the LPC1114 need to run at 50MHz frequency.
3. Install the Colink2 for MDK driver.1) Install USB driver
Ø       Power on Colink2 for LPC1100 board, pop-up found hardware dialog box, wait for the pop-up hardware installation wizard;
Ø       Choose "From a list or specific location (Advanced) "à "Search for the best driver in these locations(S) "à Check the "include this location in the search (O)"à "Browse "(point to the driver directory of the CD-ROM, 04-Tools\colink_for_lpc1100_driver), then the next step to complete the installation.
Ø       After a successful installation, indicating a successful hardware installation, you can use.
2Configure MDK
Ø       Copy colink2.dll and colink-agdi-lpc1100.dll from directory 04-Tools\colink_agdi_for_lpc1100 of CD-ROM to BIN directory of the Keil Installation path. For instance: D:\Keil\ARM\BIN\. You can download the latest plugin from CooCox formal website www.coocox.org.
Ø       Add this sentence ' TDRV50=BIN\colink-agdi-lpc1100.dll("Coocox Colink For LPC1100 Debugger") ' in the [ARMADS] section of Tools.ini file in the path of Keil's installation.
Ø       Choose "CooCox Colink2 Debugger" when degugging.
(6,403 Views)
Are you trying to get familiar with LabVIEW or promote some business?
(http://translate.google.com/translate?hl=en&sl=zh-CN&tl=en&u=http%3A%2F%2Fwww.coocox.com%2FForum%2Ft...)
(6,397 Views)
