LabVIEW Embedded
How to encrypt ARM VI ?
Hello, I passed the following encryption ARM VI, it can not compile correctly? Is there any good ways to encrypt my private algorithms ARM VI?
20473iF8F55F7A7B151209
(6,535 Views)
I donnot think protect VI is necessory after deploy VI to arm target. As you know the VI have been compiled to C code.
So I suggest you can do that after compile and deploy VI to the ARM.
(6,508 Views)
Thank you for your reply! With the extensive use of LabVIEW for ARM, engineers have not quite like detailed analysis of C code. And compiled C code difficult to read, do not know how to call. If you call the library, so back to the traditional development mode ... ...
(6,497 Views)
