LabVIEW Embedded
How do I boot BF537 target to run stand-alone code
I've been running debug code on my BF537 target successfully, but I'm uncertain how to deploy or download code that will execute from boot up w/ no JTAG tether?  I've been running in Boot mode 6 (TWI host slave mode).
I tried removing the Debug Option in the Build Options, then deploying to Target.  Changed Boot Mode to 0 (External Memory) & 1 (Flash Memory), but that didn't work?
What am I missing?
EDIT: I'm running LabView 2009.
Any insight is much appreciated!  I feel this should be fairly simple?
(7,975 Views)
Saving a Program to the Flash Memory of an ARM Microcontroller
I will see to it that this article includes the keyword "Blackfin" such that it comes up in future searches.  The instruction is the same regardless of the ARM or Blackfin target.
Kevin S.
(7,952 Views)
No luck booting from flash...
- Set Target Boot switch to Boot from Flash (1)
- Built application (with no debugging) - no issues
- Deployed to Target - no issues
- Run Target - no issues, Code running (a simple serial Tx loop)
- Remove JTAG - no issues, code continues to run
- Cycle Target power - Code does not restart (no serial stream)
Am I missing something?
(7,943 Views)
Do you have the lwIP stack enabled in the build spec?  If so, you have to have an ethernet cable plugged into the board before the code will start.  (Plug in the cable before the reboot.)
Kevin S.
(7,941 Views)
Unfortunately not.  See attached for all settings.
I'm also using the Blackfin toolkit under evaluation.  Not sure if that matters, as it says its fully functional for 30 days.
(7,933 Views)
Stranman,
Give me just a bit to get a working Blackfin system.  (The current version of the VDSP++ compiler used in LabVIEW 2009 doesn't play well with Windows 7 or VmWare.)
Kevin S.
(7,925 Views)
Accepted by topic author Stranman
Stranman,
I apologize - the instructions for generating startup code for Blackfin processors are indeed different.  They are outlined here:
Programming the Flash Memory of the ADSP-BF537 EZ-KIT Lite [article no longer available]
Kevin S.
(7,909 Views)
