LabVIEW Embedded
Hard coded TgtSupp.dll
I'm creating a new target based on the Unix Console. After using the target creation utility then closing and restarting LE the target list showed two "Unix Console" entries. I verified the TgtSupp.ini file of my newly created target had the proper name. After a little investigation I found that the default TgtSupp.dll that is unix folder doesn't read from TgtSupp.ini but instead hard codes the name to "Unix Console". After replacing the DLL with one from another directory it worked as expected. Just and FYI.
Andy
Systems Engineering - National Instruments
(7,464 Views)
Thanks Andy for your investigation. We will fix this for the next release.
-Andrew
(7,462 Views)
