LabVIEW Embedded
Error generating debug information
Hello, I'm having LV2009 ARM module and MCB2300 (LPC2378 uP). When trying to build an application (simple code or example) after linking this error appeares:
Status: Error
Error generating debug information.Error in expression
  Detail: [UVSC_DBG_CALC_EXPRESSION, MSG: 0x200A, STATUS: 0xD]
 (13)
Rarely I can build an app and even run it.
Also I've noticed strange error message in uVision that I'm restricted in code size of 32kB. But the module and realview were properly activated after isntallation.
What's the problem?
(6,050 Views)
Hi Crowbar,
It sounds like Keil uVision is not yet activated. For instructions on how to do this, please see the following document:
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/e578e1bd8a13b3af8625755a0050962b?OpenDocument
Can you successfully run an ARM example from the example finder?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(6,020 Views)
