LabVIEW Embedded
Does Labview Embedded Development module support LPC2210 or S3C44B0?
     Hello,Does Labview Embedded Development module support LPC2210 or S3C44B0. I want to use the the Phytec LPC229x, eCos target for the lpc2210,but lpc2210 can't support ISP,can i use the JTAG to download the redboot?
otherwise,do i need to rebuild the redboot?Thank you!
i like thinking ,i enjoy doing the work.baxia
(6,667 Views)
I see that the LPC2210 has a serial JTAG port for debugging and trace. The thing to check would be to see if the eCos toolchain supports downloads through JTAG. It probably does. On a side note, I see that Realview/RTX also supports the LPC2210 (http://www.keil.com/arm/chips.asp) and if you are not set on eCos, you could use the LabVIEW Embedded module for ARM with the LPC2210, this is probably simpler.
-Jaidev
Senior Product Manager
(6,660 Views)
Hello,Thank you for your answer.NOW my lab need buy a new LPC229X,Could you tell me where i can buy the one that the embedded development module support?Because i want to use the phytec_lpc229x target?
(6,646 Views)
You can buy an evaluation board from Phytec: http://www.phytec.com/products/sbc/ARM-XScale/phyCORE-ARM7-LPC2294.html.
This should work with the LabVIEW embedded module.
Jaidev
(6,640 Views)
