LabVIEW Embedded
CAN stack overflow
I am trying to implement a CAN communication network between 2 ARM 6 Processors.  The hardware is custom, but matches the MCB 2300 archetecture.
Each board sends and recieves 1 message on the bus, they are using a recieve ID filter to only recieve the message they want.  The baud rate is 500Kbps and each board sends its message every 10ms.  Each board reads the message with a timeout of 100 ticks.  I keep getting a stack overflow error and increasing the stack size will just take make the error take longer to occur.  Attached are my VI's for each board.
(6,101 Views)
This problem is resolved.  Thank you for viewing.
(6,084 Views)
