LabVIEW Embedded
A simple tcp or udp example for ARM embedded
I purchased the embedded ARM for the EK-LM3S8962 board. Could someone point me to a simple example to run a udp or tcp client on the ARM?
thanks,
Bill
(6,518 Views)
Hello Bill,
We have a shipping example that will show you how to use your LM3S8962 board as a TCP client or server. You can find this example by navigating from the Menu Bar Help»Find Examples... Once the dialog box opens go to Toolkits and Modules»ARM»Luminary Micro»Protocol Drivers»TCP.lvproj.
This example should be enough to get you started. Be sure to let us know if you have any additional questions.
Stephanie
Applications Engineering
(6,512 Views)
Ok thanks I found it.
(6,486 Views)
