LabVIEW Electrical Power Toolkit
measuring power and current
 I have a Crio 9022 and the NI 9227 and NI 9225.  I have Labview Development version, I do not have the FPGA nor the Electrical Power Suite.  Can I still measure power from my system?
(6,305 Views)
If you want to utilize 9225/9227 to acquire the signals, you must insert them into one cRIO or cDAQ chassis. If you have only one 9022 controller, I am afraid you cannot use the 9225/9227.  So firstly, you need to setup a full set of cRIO system.
For simple power measurement, the FPGA-based processing is not required. You could install Eletrical Power Suite (base version), and there is a palette "Basic Measurement". It is free and doesn't depend on FPGA. It includes the basic measurement VI for power (active power, inactive power, etc).
(6,297 Views)
You can use a single 9022 since it should have a4 or 8 slot chassis.
You will need some level of FPGA since you need to capture the data as waveforms and the scan engine will but be fast enough.
Cheers,
James
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(6,287 Views)
