LabVIEW Electrical Power Toolkit
Error 363357 Electrical Power Suite
Hi everybody,
I am trying to measure the torque, load & efficiency of motors using cRio9023, When I run the program the error code 363357 is shown due to the sample rate not being constant.
Viewing the help & some examples, the solution is re-sampling the waveforms, but I can´t do that.
Please help me.
Thank you in advance.
(5,221 Views)
Did you compile the FPGA VI in your project? If not, please compile the FPGA VI fistly.
You mentioned re-sampling is necessary based on the help, could you please tell me the provenance information?
Thanks!
(5,068 Views)
