LabVIEW Development Best Practices Discussions
front panel background image
Hi,i have faced one problem regarding front panel background image .when i choosed the BG image using frontpanel property node,i can feel my program execute slowly?,if i select "none image" its executes fastly.
i have doubt now,  is that image affect the speed of execution?
Raj
(6,999 Views)
have you tried setting the image this way: http://www.eyesonvis.com/blog/2007/03/labview-ui-trick-panel-wallpaper.html ?
does it make a difference in speed? You might want to post your code too so people have more information to hep you.
Also, check the User Interface Interest group: https://decibel.ni.com/content/groups/ui
Good luck,
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(3,764 Views)
It doesn't have influence on the execution of the diagram code but a lot of influence on the update of the user interface, especially if you put anything on it that uses transparent colors or (gasp!!!) the 3D controls with alpha shading. Anytime such a control is updated and is invalidating any area that contains information from the bitmap this bitmap is redrawn and then consequently all the controls on top need to be redrawn also.
Rolf Kalbermatter  My Blog
(3,764 Views)
