LabVIEW Development Best Practices Discussions
Upgrade to version 1.7 of Subversion?
In the past few months, a new version of Subversion and Tortoise SVN came out, v. 1.7 (followed rapidly by, 1.7.1 and 1.7.2 fixing various bugs).  There are a fair number of new features in this version, including a new Working Copy structure.  I was wondering if people have started using this new version, and if anybody has had problems using v. 1.7.x with LabVIEW?
(7,631 Views)
I'm using Tortoise SVN1.7.2 with LV2011 and having very good luck.  I like the new working copy single .svn /_svn directory structure a lot more than before.  I am not using the integrated source code management with LabVIEW -- I do all my lock/ commit from windows explorer.  Not having any problems with 1.7.2 interfacing with older SVN servers, or mixing client versions of 1.7.2 and 1.6.x both working on the same repository.
(4,881 Views)
D*,
not having done the upgrade (yet), I found this blog entry. Seems quite interesting to update...
Greetings from Germany!
UF
(4,881 Views)
We are using TortoiseSVN 1.7.2 here, too. We haven't encountered any major issues. (There is no longer an option to use _svn folders, but that is not really a problem.) The performance improvement on the execution of update or clean-up operations on top-level folders is quite noticeable.
(4,881 Views)
Yep, 1.7.x is a good upgrade - there are a handful of neat features, and the localization of each project's repository is a good move.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(4,881 Views)
In order to use 1.7.x with < 1.7.x repositories, your local copy must be upgraded to the new SQLite format. The new format is awesome - it's faster and has a smaller footprint (no more .svn directories everywhere, woo!). Be wary, however, as a fair number (4 out of 12, or so) either didn't convert properly or developed erractic symptoms of non-existant changes in the working copy that would corrupt the entire checkout when I tried to revert or cleanup.
I converted using 1.7.0, though, and I'm running 1.7.1 now so maybe they've worked out the kinks.
(4,881 Views)
