LabVIEW Communications System Design Suite
.vi files access using Labview Communication Suite
Can't I access labview files from Comm Design suite?
What I see is it has got all the functionality I would be needing to program a USRP which I other wise use to do with Labview.  Why .vi files are not being supported by cmm suite?
2. If I want to design a system comm suite is enough or I still need to buy Labview Package?
(6,031 Views)
Accepted by topic author Wired_
You can download the VI conversion tool here: http://www.ni.com/gate/gb/GB_INFOCODECONVLV/US
(6,007 Views)
Thanks!
(5,998 Views)
Hello Wired_,
With regards to your second question, LabVIEW Communications will allow you to design, develop, and test your communication algorithms.  With this software, you will not be able to build your application into a executable format outside of LabVIEW Communications.
Thomas C.
FlexRIO Product Support Engineer
(5,522 Views)
