LabVIEW Communications System Design Suite
Missing 'Multirate Diagram SystemDesigner Plugin
  • I receive the following error when I attempt to open an existing project in Labview NXG with USRP 2940R :
          "Your System is missing the following:
           'Multirate Diagram SystemDesigner 'Plugin
            Visit ni.com/info and enter the Info code "NXG_Load_Failure" for more information"
  • Any assistance on this issue is highly appreciated.
(4,373 Views)
I am having the same problem.
Seems like you have to install the Communications System Design Suite as stated here [broken link removed].
Lorenzo
(4,058 Views)
Hello Lorenzo, did you have the problem solved?
I had the LabVIEW NXG 5.0 installed and still facing the same problem. Also tried codes migration to version 2.1 and then to higher version and neither worked.
Have you solved the problem or known which driver or addon we should install to fix this plugin error?
Kind regards
(3,614 Views)
