LabVIEW Communications System Design Suite
Location for record.gvi ?
Is the record.gvi file supposed to be one of the default examples? I went through most all of the example tree in the comm suite eval and was unable to locate it. It seems simple enough to re-create, just curious if I was missing something.
-Tim
(5,761 Views)
Tim -
Are you referring to the example RF Record and Playback with USRP and LabVIEW Communications?
If yes, the correct file is now available for download off of the page and will open in LabVIEW Communications.
Hope that helps!
(5,750 Views)
