LabVIEW Communications System Design Suite
LabView communication suite LTE frame Work
I have installed Labview communication Design Suite compatible -  LTE Framework on my system.
In it the framework is basically appears to be design for one UE and one ENodeB communication. As per the manual of the LTE framework, the code is configured on the LAbview and then implemneted on the FPGA. The main problem,I am facing is, how to identify and configure the existing LTE framework code for 2 Recievers.
(4,771 Views)
did you find this out? I am also trying to do this.
(3,967 Views)
