LabVIEW Communications System Design Suite
Error with memory constant
hello guys,
Somebody can explain how working memory constants in clock-driven logic? (Labview comms 2.0, FrameWork 802.11) I'm create memory and put values in *.grsc file (Matrix and then reading rows). the compiler doesnt show me errors and warnings on all levels of program, but then i'm build for FPGA file i have getting error! This is with memory constant and memory read blocks. I can't use Create Memory with Initial Values becouse i have more than 1024 numbers.
Can you help me to find solution for this problem
thank you.
Message 1 of 9
(5,256 Views)
After you receive that compile error can you open up the main FPGA gvi. I didn't see any errors either when I was still on the project screen but when I had the FPGA gvi up I saw errors related to the compilation.
Message 2 of 9
(5,203 Views)
Labview doesn't show any errors. I haven't errors at all levels.
Message 3 of 9
(5,200 Views)
That is strange, how are you configuring the memory item in the resource file and how are you actually using the memory item in the project?
Message 4 of 9
(5,176 Views)
I'm creating capture data with import Data from csv file, and then loading in to memory with using field "Copied from". this matrix uses for Matrix Multiply block. Reading from memory Array's adress (Vector, row from matrix).
In simulation mode it's work well, but it doesnt build.
Message 5 of 9
(5,167 Views)
togoto,
Can you be a bit more specific on where you are placing this memory item and how it is being used? If you can attach the gvis that you have altered from the 802.11 project that would be helpful. Also, can you explain how you set up the data for the memory item? It appears that the memory item is a 2d array of complex doubles but if you could guide me through how you set that up it would be helpful.
Message 6 of 9
(5,055 Views)
Matt,
unfortunately i can't attach whole file because it's under NDA, sorry Matt. Memory item placed near with matrix multiply (image). This is construction all in *.gcdl file.
"setup the data for the memory item"
1. choose create new value
2. in For Capture.gvi move there my data from Captured Data with replase
3. chanche type of data and with righ click capture data again
4. in memory choose new captured data with my type.
Message 7 of 9
(5,020 Views)
togoto,
When reading from a BRAM memory you must wire the output to a feedback node as the read operation takes one cycle.
There are some limitations to our error reporting which don't report this error until after you try to build, but you should have seen something like this after the failed build:
I think this is the root of your issue.
GG
Message 8 of 9
(4,950 Views)
Unfortunately, it doesn't help. I still get error while compile whole project. (on Creating VHDL).  Display Errors and Warnings still empty. 😞
Message 9 of 9
(4,939 Views)
