LabVIEW Communications System Design Suite
Communication between LabVIEW and custom hardware using TCP/IP & UDP IPv6 protocol .
Hi
I am working on a project where I have a need to communicate custom hardware using TCP/IP & UDP IPv6 protocol.
If any one have any idea about how to communicate custom hardware using TCP/IP & UDP IPv6 protocol. I have done with IPv4 but my customer require using IPv6.
If any one have work on it please help me to get the solution.
Thanks in advance.
(3,388 Views)
Hi Skant,
I think you might be posting in the wrong forum. Are you using LabVIEW Communications? I noticed that you posted a similar question in the Instrument Control (GPIB, Serial, VISA, IVI) forum. If you are not using LabVIEW Communications then that is the best place for you to post to get a more applicable response.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(3,324 Views)
