LabVIEW Communications System Design Suite
Coding using MT RS Encoder Decoder
I want to implement a RS(255,239) in the attached VI. Can anyone help? I don't understand what'is wrong?
I use an MT Bit Generator (3824 bits) -->  MT Pack Bits (bits per Integer = 😎  --> MT RS Encoder (255,239 bits per symbol = 8 )
When accessing the RS Encoder I get Error -1 occured The NUmbers cant be Zero
(6,741 Views)
Hi alexpas,
When running your VI, I also the following error message :
Error -21892 occurred at mod_Validate RS code prms.gvi "RS Galois primitive element must be relatively prime to the Galois field order 2^m-1 in GF(2^m)."
Modifying the Message bit count may solve your issue,
Regards
(6,673 Views)
Actually the message bits are selected on purpose to be t*239 in order to meet the requirement for the MT RS encoder as it is a pack encoder. Nevertheless I've tried that but still the same errors!
(6,647 Views)
Hello alexpas,
I was able to reproduce the error -1. I have done some investigation into the error and found that it is thrown by one of the VI's subVIs. I modified the mod_Configure RS attributes.gvi into to resolve this error.
Please download the attached VI, and use it to replace the <LabVIEW Comms 1.1>\Resources\vi.lib\Native\mod_Configure RS attributes.gvi.
This should resolve the error. Please see the attached VI.
Thomas C.
FlexRIO Product Support Engineer
(6,551 Views)
Thank you Thomas,
Your assistance on my issues is priceless.
(6,533 Views)
Thanks! I really appreciate your feedback!!!
Thomas C.
(6,526 Views)
