LabVIEW Communications System Design Suite
Build failed at synthesizing step. (USRP-Rio FPGA)
Hello.
I am now converting the FPGA code which I used in LabView Comms v1.1 to v2.1.
However, the multirate code (.gmrd) that was used correctly in 1.1 indicates a following error in 2.1.
At synthesizing step (step 6), 'Build errors' is occured with 'Could not get bitfile from worker.' message.
I have tried many ways, but I can not find any reason, so I ask for help.
I attach a sample project that contains the FPGA application code.
Thank you.
Han.
(4,063 Views)
(4,061 Views)
Hi Han,
The log file that you provided is truncated and I do not see any errors listed. That suggests to me that the compile worker crashed or exited unexpectedly.
I was able to reproduce while compiling locally. The log failed at exactly the same point.
It might be worthwhile to try compiling on the cloud if you haven't already. I am trying that now. EDIT: Cloud compilation also fails. Please open a service request as mentioned below so we can dig into this.
Also, I think that it would be best for you to work with our support team by navigating to ni.com/support and opening a service request so that we can take a deeper look at this issue and to try to find a workaround for you.
When you open the service request please provide:
- The 1.1 version of the project in addition to the 2.1 version attached here
- OS (if Windows 10 then provide the version such as 1709, 1803 etc.) and system specs
Kyle S.
(4,042 Views)
