LabVIEW Communications System Design Suite
Auto Switching Between RX-Tx
I am implementing normal TDD type system where Tranmsitter and receivers switch between receiver and trasnmitter chain.
I am using NI-PXIe 1082 hence can control two USRPs from one graph/Panel.
How to insure :
1. Rx switches from trasmittion to reception
2. Tx switches from reception to transmission
3. Tx switches from transmission to reception
4. Rx switches from reception to transmission
Each steps are progressively in time domain.
I want to switch in two different cases: fixed time dwell and fixed packet transmitted/received.
Any example I can look in? Key points to change?
(6,683 Views)
Hello Wired,
Sadly, this functionality does not exist. R&D is aware of this limitation in LabVIEW Communications and they are working towards making an example in future versions of the product.
Thomas C.
FlexRIO Product Support Engineer
(5,689 Views)
Has the feature got implemented?
I heaed that Switching TDD was implemented in MIMO design.
Can you share reference?
(4,878 Views)
(4,359 Views)
