LabVIEW Architects Forum
Tuesday, December 5th, 2017: Agenda
Meeting Logistics
  • Location: Mopac C, 1S13 @ NI headquarters 11500 North MoPac Expressway, Austin TX
  • Date: Tuesday, December 5, 2017
  • Time: 6:00 PM Central Time
  • Duration: ~2 hours
  • Format: Presentations
  • Food: An accurate headcount helps here so please register if you are attending in-person. Please register here. Even NI employees can use the online registration, there is no longer a need for a separate NI only email. If you are attending remotely, there is no need to register, just join us using the Remote Attendance coordinates below.
Meeting Topics
But I Hear that LabVIEW Does Not Work with Git or Hg?
Presenter:  Fabiola De la Cueva
Blog post of a similar presentation Fabiola gave at Dev Days including video of the presentation here:
http://delacor.com/configuring-hg-or-git-to-use-labview-compare-and-labview-merge/
Optimizing LabVIEW FPGA: Going From 1000% to 90% Utilization of cRIO/sbRIO
Presenter: Damien Gray
Faced with a custom high-speed, highly synchronized, mixed digital and analog I/O system, the logical solution is an FPGA. RT solutions were simply not fast enough. Compiling a partial RT solution into the FPGA gave a utilization of over 1000%. Optimization brought this down to under 90%, sped things up dramatically, and allowed new functionality to be added relatively simply. It even compiled at 120MHz. How did I do it? Come find out!
Remote Attendance
Thanks to Sixclear for sponsoring remote connection. If you cannot make it to NI, join the web conference
  • Join the Screenshare
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(4,465 Views)
Good topics!
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,373 Views)
