LabVIEW Architects Forum
Meeting Tuesday, November 17: Solving a Root Loop issue
Link for the registration at https://www.meetup.com/LabVIEW-Architects-Forum/events/274366755/
Meeting Logistics
  • Location: From the comfort of your own home. This meeting will be online.
Meeting entry info: 461 512 698#
+1 512-851-8323   United States, Austin (Toll)
Local numbers
  • Date: Tuesday, November 17th, 2020
  • Time: 6:00 PM Central Time
  • Duration: ~2 hours
  • Format: Presentation followed by a discussion
Meeting Topic: Solving a Root Loop issue
Fabiola De la Cueva from Delacor will do a session on how they solved a root loop issue. We will have some time for Q&A at the end.
"See you" on Tuesday, November 17yh, 2020.
The LAF organizing team (Craig, Chris, Allen, and Fab)
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(3,192 Views)
Is this recorded somewhere?
Can this be shared?
Thanks !
CLA, CTA
(1,486 Views)
It does not appear to have been posted to our Youtube channel, so, regretfully, it is likely the recording has been lost.
(1,473 Views)
ok, no problem, I wanted to ask if I had a chance
CLA, CTA
(1,461 Views)
If you are looking for what the "Root Loop Issue" was that got solved...  I believe it to be the one that caused a change in the way DQMH starts a module. Previously it used the Run VI method, but that requires the Root Loop to execute. If you have a user holding down the mouse button on a menu or something that can block the root loop and prevent the module from starting.
For DQMH 5.0 Release Notes:
#DQMH-599 Singleton and Cloneable Module templates updated to use Start Async Call instead of Run VI method for launching Main VI
https://wiki.dqmh.org/dqmh/release-notes/dqmh50
(1,452 Views)
