LabVIEW APIs Documents
Hyper Terminal RS 232 & Serial Port Test
Hi All
I have developed Utility which worked like Windows hyper terminal utility.
HyperTerminal is a program that you can use to connect to other computers, devices and host computers.
HyperTerminal has capabilities beyond making connections to other computers and devices. It can, for example, transfer large files from a computer onto your portable computer using a serial port rather than requiring you to set up your portable computer on a network. It can help debug source code from a remote terminal. It can also communicate with many older, character-based computers.
HyperTerminal records the messages passed to and from the computer on the other end of your connection. It can therefore serve as a valuable troubleshooting tool when setting up and using your serial port. To make sure that your device is connected properly or to view your device settings, you can send commands through HyperTerminal and check the results. HyperTerminal also has scroll functionality that enables you to view received text that has scrolled off the screen.
  • Connect / Disconnect: Clicking on this button, selected com port will connect or disconnect.
  • Send File: Clicking on this button, file section window will open. User can select the file which supposed to send.
  • Log file: Clicking on this button, User can log the data to the selected file.
  • Clear Screen: Clicking on this button, the display screen will be cleared
  • Autowrap: This will wrap the text
  • Local Echo: This will generate an echo
  • CR=> CR/LF: Send End character
  • Auto scroll:   Will scroll display automatically
  • Display Style: Select the display style, like Normal, Hex code display
  • Exit: Clicking on this button, application will exit.
Also Developed for to test the serial port
Serial Port Test
New Version is Updated - Version 1.2
Zip file includes exe
New Version is Updated - Version 1.3
Save to file option is added
Please Give your comments
Prabhakant
Regards
Prabhakant Patil
Comments
Prabhakant_Patil
Member
Member
on
Any suggetions ????
Regards
Prabhakant Patil
Albert.Geven
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Hi
A real LabVIEW implementation of Hyperterminal is a long missing feature, so that is very good.
I would like it to be this program available in two forms in which one is as basic as possible to function also as an example.
But then it needs more comments in the coding and all terminal labels visible.
First an irritating question: Why did you recolor all basic elements in the blockdiagram, it makes it less readable.
One of the differences between LabVIEW(VISA)  and Hyperterminal is the speed in which characters are sent out.
Hyperterminal is definetely slower and for some devices a char by char output is necessary. This could be added.
But I'm glad you had the guts to complete this and publish it here.
Thanks.
greetings from the Netherlands
SaidElshayeb
Member
Member
on
Thanks, thats awesome
Lecturer
Machanical Power Department
Helwan University, Egypt
Prabhakant_Patil
Member
Member
on
Thanks for such nice reply.
Regards
Prabhakant Patil
Prabhakant_Patil
Member
Member
on
Regards
Prabhakant Patil
Albert.Geven
Trusted Enthusiast
on
Hi
It seems that the links for the zip and rar files ar not correct. They point to the document pages, not to the zip and rar files
Prabhakant_Patil
Member
Member
on
HI
It might be NI websight problem.
I tried to download another document, but it showing same problem to me.
Regards
Prabhakant Patil
VuD
Member
Member
on
We apologize for the inconvenience.  The links should be working now.  We had a minor issue with file paths that our team resolved this morning.
Claire_Reid
NI Employee (retired)
on
Hi AlbertGeven and PrabhakantPatil-
Regards
Claire Reid
Claire Reid
Albert.Geven
Trusted Enthusiast
on
thanks for fixing it
Prabhakant_Patil
Member
Member
on
Thanks a Lot for fixing it
Regards
Prabhakant
Regards
Prabhakant Patil
Prabhakant_Patil
Member
Member
on
Please click on like if you like it.
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Regards
Prabhakant Patil
Albert.Geven
Trusted Enthusiast
on
Hi
Which file should I download?
You are talking about version 1.2 but for hyperterminal the highest number is 1.1
Prabhakant_Patil
Member
Member
on
Sorry,
Version 1.2 for the serial port test and
Version 1.1 for Hyper Terminal.
Regards
Prabhakant Patil
Contributors
