LabVIEW APIs Discussions
how to get the image of a block diagram constant?
I have a cluster constant on my block diagram and I'm trying to get it's image to display it in a picture control.
We can get the image of a cluster control but that not what I want... Is there a way?
Epictetus
Antoine Chalons
(6,401 Views)
You can do what the CCT does - get an image of the entire diagram, then cut out just the section you want.
___________________
Try to take over the world!
(3,896 Views)
True, great point! I hadn't thought about it 😮
Beside that is there any "pure scripting way"? I mean... for a cluster control there are methods to get the fp & bd images, I was hopping to find a method to get the bd image for a cluster constants.
Epictetus
Antoine Chalons
(3,896 Views)
Get Image methods are relatively new for block diagram elements. Eariler there was only the method for whole the diagram. So we may expect that in future vesions it will be implemented for constants as well...
(3,896 Views)
If you get the full block diagram image, you can crop it programmatically by using the position and bounds properties of the cluster to determine where to crop.
(3,896 Views)
Yep, I used the CCT function that does exactly that
Epictetus
Antoine Chalons
(3,896 Views)
