LabVIEW APIs Discussions
Working with control parts programmatically
If you're manually editing a control, you can go to the Window menu and select Show Parts Window, which allows you to cycle through all the different parts that make up that specific control.
Is there a way to select/view these parts using scripting? I'd like to be able to save each image that makes up a control through scripting.
I checked the property nodes, but I didn't see anything.
Thanks a bunch.
David S.
(4,843 Views)
Hello dstrandb,
there was a similar discussion regarding boolean controls some time ago.
Have a look here:
https://decibel.ni.com/content/thread/4901?start=0&tstart=0
Bets regards,
Balze
(3,691 Views)
