LabVIEW APIs Discussions
What types of LabVIEW right-click menu features do you want to create?
This one's definitely a little more complex:
When you're dealing with flat sequence structures, it gets annoying to add a new frame, and then move the code into that frame (and reconnect the wires).
It would make things much easier to be able to insert a divider (spit a frame) or remove a divider (merge two frames).
Marshal Horn
Message 51 of 53
(1,218 Views)
Hi everyone!  I wanted to let you all know that discussions about the JKI Right-Click Framework should now happen in the new JKI Right-Click Framework Group.  If you visit that group, you'll probably notice some interesting new developments
Message 52 of 53
(1,218 Views)
AristosQueue wrote:
  1. Select an entire set of FPTerminals, popup and select "Create Array of References", which would do Create Reference for every one of those controls and then drop a Build Array prim and wire all the created references up to that prim.
I posted an example of this here.
___________________
Try to take over the world!
Message 53 of 53
(1,218 Views)
