LabVIEW APIs Discussions
[Scripting] Copy control from running VI
Hey all,
I have an interesting situation that I can't figure out how to do.  I want to take a control from a running VI and replicate it on a new VI (with the same colors, properties, etc).  However using the TopLevelDiagram:Make Selection and Copy selection methods, you can only copy from a VI in edit mode.  Does anyone have other ideas on how to accomplish replicating a control using VI Scripting?
Thanks for the help,
David
(8,706 Views)
Why can't you get a refnum to the control you want to copy, read it's properties, create a new control, and set the properties?
(5,577 Views)
I can get you close, but not the exact control...
The forum won't let me post images at the moment... I'm not sure why... so I posted the image of the diagram here:
http://forums.ni.com/t5/LabVIEW/Create-Control-From-Reference/m-p/1539816/thread-id/570676/highlight...
(5,577 Views)
Just use the VI's Create by Reference method. I added a snippet in AQ's thread.
___________________
Try to take over the world!
(5,577 Views)
Hey thanks everyone for the advice.
Steve:  This would definitely work, just requires more work when I was pretty certain there was a much simpler method.
AQ:  This copies the data type of the control only, I was looking to copy all of the properties, class type, colors etc.
tst:  This seems to do exactly what I was looking for!
Attached is the VI example in case anyone stumbles across this later on...
(5,577 Views)
*head smack* I forgot about that method. Good catch, tst.
(5,577 Views)
