LabVIEW APIs Discussions
Minor bug with Case Structure Tunnel Names
Here is an admittedly minor bug with an easy workaround, but it did annoy me for quite some time until I figured it out.  I was working on a RCF plug-in to change a selected tunnel to the Case Selector.  I wanted to maintain as much wiring as possible so I needed to find "orphan" tunnels that were connected to a wire I was about to delete.  Easy enough, first check the owner of the Wire Terminals and look for a Class Name of Tunnel.  It turns out that Tunnels are called SelectorTunnel and the SelectorTunnel is called Tunnel.
I have attached a simple VI to show this.  TestCase.vi is a simple case structure with a single wire connected to the SelectorTunnel and two Tunnels.  ShowCaseSelector lists the owner of the wire terminals and you see two SelectorTunnels and one Tunnel.  When I highlight the Tunnel and you see the SelectorTunnel is the one selected.
Just letting you know.
LV9 SP1
Still time to fix for LV10 (haha...)
Message 1 of 1
(3,388 Views)
