LabVIEW APIs Discussions
I there a way to find deprecated property/invoke node calls?
The Get VI Dependencies method I mentioned above returns both the dependency names and the dependency paths.  It also gives you good control over what a "dependency" means, which is why the previous properties were deprecated.
Message 11 of 16
(2,601 Views)
Can someone explain what is a "Standard VI" and a "Generic VI" as refered to in this "Get VI Dependencies" invoke node?
Thanks in advance.
Epictetus
Antoine Chalons
Message 12 of 16
(2,601 Views)
Standard VIs are just that - a VI (or subVI, depending on your point of view).  It is not a global, control, polymorphic or generic VI.  A generic VI is a very buggy internal feature that may or may not ever make it out the door.  However, it is another VI type, so is covered by the method.  It is very similar to a standard VI.
Message 13 of 16
(2,601 Views)
Right so I guess it doesn't change much if I include generic VIs or not since anyway my project don't have any of these.
Thanks for explaining!
Epictetus
Antoine Chalons
Message 14 of 16
(2,601 Views)
Here's what I came up with : a VI that looks through a project and highlights deprecated property nodes (sorry for the huge BD) :
http://forums.ni.com/t5/image/serverpage/image-id/83410i5B82D191319F5BD1/image-size/original?v=mpbl-...
Epictetus
Antoine Chalons
Message 15 of 16
(2,601 Views)
just posted this : Find deprecated nodes
Epictetus
Antoine Chalons
Message 16 of 16
(2,601 Views)
