LabVIEW APIs Discussions
Adding Event case to event structure
I want to add new cases to event structure using LabVIEW Scripting APIs.
I could locate "Add frame" Method. It adds new frame. but how i can set the triggering criteria for the frame?
(5,164 Views)
The event structure options are not exposed, even after installing the
scripting API.
NI is aware of the demand for this, so maybe 2010 will have it.
___________________
Try to take over the world!
(3,822 Views)
That functionality has not been exposed in the scripting API.  If you post a suggestion in the idea exchange, I will kudo it.
(3,822 Views)
