LabVIEW APIs Discussions
3 signals on a chart
hi,
i want to plot 3 signals on a chart
but when i do this, on the chart appear one signal only that is the sum of 3 signals
i want that the 3 signals appear all in same time
how i can do this?
(4,618 Views)
Hi iman,
it plots the sum of those signals because you have programmed it that way: you use an ArraySum function...
Why don't you ask programming specific questions in the forum?
(3,863 Views)
iman, try using the Index and Bundle Cluster Array function for your individual arrays, although it is not clear what you intended to do with the one single point at the end.
(3,864 Views)
