Hobbyist Toolkit
LINX Uninstall on Raspberry Pi 4
I've tried to uninstall lvrt-shroot with these commands:
sudo apt-get --purge remove lvrt-schroot
sudo apt-get remove lvrt-schroot
sudo apt-get purge lvrt-schroot
The result is the same for each command:
E: Conflicting values set for option Trusted regarding source http://feeds.labviewmakerhub.com/debian/ binary/
E: The list of sources could not be read.
I follow the link in the error and it displays the 404 error, which I'm sure this is why it isn't deleting the package.
I'm a linux beginner, so can anyone tell me how to delete the lvrt package?
Thanks for any help,
Joel
(2,467 Views)
First you need to disable and stop the services as following
sudo systemctl disable nisysserver.service
sudo systemctl disable labview.service
sudo systemctl stop nisysserver.service
sudo systemctl stop labview.service
then try to use your commands to remove lvrt-shroot
or use this one
sudo apt autoremove lvrt-schroot
(1,925 Views)
