JKI State Machine Objects
Why the reentrancy "Initialize Dependencies Attribute.vi" is set to "Preallocated"?
Hi all,
I am new to SMO architecture. I starts to read the source code of SMO class step by step to understand it deeply.
I found that the reentrancies of constructors (Initialize ... .vi) of all sub "Attribute" classes are non-reentrant, except "Attribute.Dependencies" class. And it is set to be preallocated.
Could anyone explain the reason for me?
Thanks for your kind explanation in advance
Godel Sung
(2,109 Views)
You were really going over the framework in some detail to have noticed that!
I'm guessing it's purely chance. Changing that VI to non-reentrant should have little effect on anything since that particular piece of code is not blocking and does not maintain any state in a feedback node or shift register.
(1,969 Views)
