JKI State Machine Objects
Webinar: Creating a Hardware Abstraction Layer using the SMO Framework
I am trying to run the HAL example.  But there seems to be missing classes.  Specifically, the SMO.Dictionary.Variant.lvclass.  I could not find it anywhere.  I'm running on LV2016 32bit.  Does anyone know where these classes should be found?
(10,446 Views)
Hi jeremy_levy,
Download OpenG Dictionary Library and install
(10,395 Views)
I'm having the same problem with missing SMO.Dictionary.Variant and I have OpenG Dictionary Library installed.
(9,944 Views)
I was able to fix the problem by running the included "ApplyMe.vipc" package
(9,855 Views)
Thank you for your comment and I apologize for the late reply.
Applying the ApplyMe.vipc file gets you all the necessary dependencies as described in the How To section on our GitHub page.
Thanks!
Javier Ruiz - Partner at JKI
jki.net
vipm.io
(9,289 Views)
