JKI State Machine Objects
Register array of events
I often want a SMO to register to an array of events. For instance, let's say my "main SMO" has several dependencies, I want the "main SMO" to listen to errors and status update of all the dependencies.
In order to do that, I convert the static dependencies cluster to an array of SMO, unbundle the public event cluster and make an array of error events and status event which are then registered:
It works but sometimes, the event structure seems to "lose the connection" with the events array and shows "#20: unknown event (0x0)" or something like that:
This happens almost all the time when I add a new method or event via the SMO editor. More annoying, it also happens randomly when I reload the Labview project: everything is broken (and it was not when I last saved the project) which is quite frustrating.
So, is there a better way to listen to array of events? If not, is there a workaround to prevent the event structure from "forgeting" about the events?
Peper
PS: I'm using Labview 2015 SP1
(6,701 Views)
Peper,
I've seen this bug once or twice in LabVIEW 2015 and it is not exclusive to the SMO framework. I'd be interested in hearing from NI regarding this bug.
Javier Ruiz - Partner at JKI
jki.net
vipm.io
(6,266 Views)
