JDP Science Tools
sqlite copy your database into RAM to speed it up
While running test I found out that having your sqlite database in RAM instead of on disk would speed up the query execution substantially.
And I found a rather simple way to "clone a database from file into memory", at first I tried with VACUUM but couldn't get it to work.
I thought I'd share my method, maybe someone has a better one.
Anyway, here's what I came up with
Epictetus
Antoine Chalons
(329 Views)
Note: that sqlite_master table also contains the exact SQL that the table was created with.  You can use that to create identical tables in your memory db (CREATE TABLE...AS... won't include things like primary or foreign key definitions and the like).
BTW, in Windows at least, the Windows File Cache generally makes things in memory without doing something like you're doing, but I think you are using Linux.
(308 Views)
Indeed I am on Linux.
Thank you for the advice, I will look into this.
Epictetus
Antoine Chalons
(297 Views)
