JDP Science Tools
SQLite Insert empty string with parameter(s)
I am trying to implement a parameterized INSERT statement with two columns that are text.  When I pass an empty string for the parameter, it inserts a NULL and not an empty string into the table.
Is there something I need to setup to have empty strings insert as empty strings and not NULL?
(9,558 Views)
I found that changing the "Call Library Function" for sqlite3_bind_text in the "Bind Text.vi" to type array of U8 and set minimum size to "Number of Bytes" input it will insert an empty string.
(9,541 Views)
I had already fixed this, but had not released a new version in a while.  I have just submitted a new version to teh Tools Network.
(8,596 Views)
