JDP Science Tools
Running actors in different execution systems
I want to run my GUI ActorNr.vi in a different execution system to all my other actors. However LabVIEW won't let me change the execution system, it insists all VIs in the moethod must use the same settings.
Any ideas on how to change one actor's execution system to differ from the others?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(1,800 Views)
I too would be interested in a solution for this, but it seems like one of those fundamental labview issues.
(838 Views)
Suggest you save your Actor.vi with a different name, then make a new Actor.vi that does nothing but call your original vi.  Then make the original vi none dynamic dispatch and set it to use a different execution system
(829 Views)
That did the trick! By doing this with my acquisition actor, I reduced the CPU usage by about 10% and noticeably reduced the jitter of the system.
(755 Views)
