04-30-2021 05:57 AM - edited 04-30-2021 05:58 AM
Hello, everyone,
My group bought a safety Module NI9351 for my experiment. through the Manual, I'm not sure how it works, and what does it work for? I guess it might be used for an emergence stop?
Does anyone have some idea about this Module?
Thank you very much.
05-05-2021
02:13 AM
- last edited on
06-16-2025
10:31 AM
by
Content Cleaner
The module contains built-in diagnostics that can monitor the status of the hardware and the integrity of the connections.
It can be used to control critical safety functions in manufacturing assembly and test cells, large physical tests, condition monitoring applications, and process monitoring and control.
Probably you can refer to these links below.
Datasheet
https://www.ni.com/docs/en-US/bundle/ni-9351-specs/page/specs.html
To program the module, kindly use "Functional Safety Editor" software.
Functional Safety Editor Download
https://www.ni.com/en/support/downloads/drivers/download.functional-safety-editor.html
Hopefully it helps.
Thanks.
