What would be the easiest way to go about writing a serial macro in labview 7? I'm familiar with c++, c and java 5.0, but I'm new to labview. What I want to do is fairly simple in those, but I can't figure it out in labview. I want to basically have a line sent through serial connection that is like "#01G+400\r" where the 01, + and 400 are inputs from the user. In java or c you could just input the numbers to a variable a, b and c and do something like cout>>"#"a"G"bc"\r"; except that it would be the serial command, not cout. Sorry if this doesn't make much sense, any help or a point in the right direction would be greatly appreciated though
